xerox 700 jamming issue
  • lion_heart
    • Jun 2014
    • 174
    Good day, xerox 700, having this jamming issue, only seem to happen when i duplex, and only when the second sheet is trying to reach the pre-registration. the first sheet would have be exiting the decurler and jam around there, hope this is a good explanation, have the pics attached. I have replaced the registration unit seeing if that could be it, but still nothing
  • Milo Wilson
    • 502
    Re: xerox 700 jamming issue
    need to replace the duplex drive idler hubs
    • EAHG
      • Jan 2020
      • 20
      Any error codes mate.
      • JulianMue
        • Feb 2018
        • 10
        Did you solve the error? I have the same problem at the moment
        • lion_heart
          • Jun 2014
          • 174
          Good day, there are a few steps that I took, maybe can help me, first check the duplex belt, and the tensioner, might have to adjust the tensioner a bit, do you hear grinding noise when you try to duplex? if that's the case you would need to purchase a duplex drive gear kit and replace those two gears. hope this helps, as it's what I did.
