xerox colorqube 8700 paper size keeps changing
  • tmw
    • Dec 2013
    • 259
    I haven't had to worry about fixing these since the tektronix & early phaser days. The original problem I had to deal with was replacing a cracked maintenance cam shaft, missing cleaning blade, & realigning the drive gears. All was successful. When powered up it printed the starting cleaning pages & all the tests I wanted.
    I brought it back to the customer & when it powered up, it wanted to print the cleaning pages on A4 & nothing I could do would change it's mind. The panel screen wouldn't show any other setting but A4. I couldn't find any menu settings through the panel or web page saying cleaning pages had to be run on A4. Eventually I cut legal into A4 & it finally ran the cleaning pages without jamming. Then it went back to showing the tray had 8 1/2 x 11. Printed tests & jobs no problem.
    Since then I've been called back a couple times because the paper keeps stopping on cleaning pages expecting A4. Got past this both times, then it seemed to recognize Lt. I noticed a few times it didn't recognize Lt right away until I open & shut the tray firmly. I don't know why it does it now when it didn't at the shop.
    I suspect maybe the paper size sensor might be flaky. I wonder if any of you that are more familiar with these can think of anything else I might be missing. I thought of flashing the firmware, but the website didn't have a download button & recommended only a system administrator should do it. I don't know if being a mac had anything to do with it.
    I'd like to thank those of you for your consideration.
  • nilak
    • Aug 2010
    • 72
    Re: xerox colorqube 8700 paper size keeps changing
    check if the paper size switch board (behind the tray) is not dislodged, like a wild guess check also bypass to be set to letter, default paper is letter, default units are inches and no sim is installed back.
    • Detonation
      • Feb 2010
      • 410
      If it is asking for A4 paper and it won't print because it actually sees Lt. in the tray, then it seems like more of a software problem than a flaky sensor. I take it you do have units in inches not metrics? If so, it's probably best too reinstall software with altboot (USB stick)
