Xerox 252 firmware
  • dalman
    • Mar 2020
    • 10
    Xerox 252 firmware
    I have a Xerox dc252 i need the firmware can any help me??
    Re: Xerox 252 firmware
    what problem are you having that makes you think you need firmware?
    • dalman
      • Mar 2020
      • 10
      Hi Phil B
      I have restored it to factory defaults and then it doesn't work.
        Hi Phil B
        hmmmmm seems you didn't follow the procedure in the manual...
        you didn't back up the data did you?
        why did you set back to factory defaults?
        are you an end user?
        • dalman
          • Mar 2020
          • 10
          -I don't have back up
          -Yes, I am end user
            yes
            YES WHAT?
            • dalman
              • Mar 2020
              • 10
              YES WHAT?
              -Yes, I am end user
                -Yes, I am end user
                hire a trained tech then.
                maybe this will teach you not to step in water deeper than you can swim in .
                • dalman
                  • Mar 2020
                  • 10
                  Thank you
                  • matej.zivko
                    • Apr 2015
                    • 7
                    And with this you help poor man? He ask for help not for grandpa advice
                    • xeroxbg
                      • Feb 2020
                      • 10
                      PWS Laptop with:
                      - DC242/252/260 SW Download Tool V1.0.0
                      - GSN Release 9.0 or Higher PWS Software
                      - GSN Lock
                      • dalman
                        • Mar 2020
                        • 10
                        Originally posted by xeroxbg
                        PWS Laptop with:
                        - GSN Lock
                        Thanks xeroxbg.
                        I don't have them.
                        I'm in the south of Sweden and Xerox technicians come from Copenhagen but Denmark is shut down due to the Corona virus. I'm not a technician but in this situation I have to find a way.
                        After restored DC252 to factory defaults , Fiery Command can't find the IP and Network icon not active on DC.
                        I guessed the problem with the firmwear.
                        What do you think ?
                        How to solve this problem?
                          Thanks xeroxbg.
                          I don't have them.
                          I guessed the problem with the firmware.
                          What do you think ? How to solve this problem?
                          you set factory defaults.. that's why the IP is lost. you have to match the ip with fiery ip scheme. factory should be used ONLY in an emergency last resort.
                          you don't have the tools nor the experience for this job.
                          hire a tech
                          • dalman
                            • Mar 2020
                            • 10
                            hire a tech
                            I can't hire tech ,all are shut down due to the Corona virus
                            • xcopytech
                              • Aug 2006
                              • 1783
                              Check crossover cable between machine and fiery
                              Do you have small bustled fiery or standalone
