Xerox 252 firmware
    Re: Xerox 252 firmware
    Originally posted by dalman
    I can't hire tech ,all are shut down due to the Corona virus
    Well maybe someone will sell you a PWS with all cables and software's needed. This is a very big problem we techs face... end users thinking they have the tools and skills needed to fix their units.
    • dalman
      • Mar 2020
      • 10
      #17
      Originally posted by xcopytech
      Check crossover cable between machine and fiery
      Do you have small bustled fiery or standalone
      I checked it out
      small bustled
      • dalman
        • Mar 2020
        • 10
        #18
        Thanks again for your guidance
        As I said : I'm not a technician but in this situation I have to find a way.
        • xcopytech
          • Aug 2006
          • 1792
          #19
          Can you make copy on dc252?
          On fiery you have a small lcd, what code you have on it
          • dalman
            • Mar 2020
            • 10
            #20
            Do you mean to copy a file with USB in the dc252?
              no just a simple copy from ADF or glass
              • xcopytech
                • Aug 2006
                • 1792
                #22
                Just a copy. To see do you have a problem with machine or with fiery
                • Detonation
                  • Feb 2010
                  • 404
                  #23
                  Exactly how did you put the DC252 back to factory defaults? Did you use 'Delete All Data'?
                  The crossover ethernet cable between de DC252 en the Fiery bustled is only needed for scanning. The large SCSI cable takes care of communication between the Fiery and the DC252. If you boot the DC252 the Fiery should also boot. There is a tiny LCD screen on the Fiery which should display '00' if all is good. After 5 minutes or so, you should be able to find 'network controller' settings in your system settings. If it doesn't show up there, you have a defective Fiery, a bad cable, or a bad video card on the ESS.
