xerox dcciii 3300 cant turn on
  • alaneong2923
    • Jul 2019
    • 17
    hello everyone,
    i have one xerox dcciii3300 used for 4 years already.my machine cant turn on but still got sound and fuser still can heat up.only touchscreen no display and also enerygy saver no power.this problem happen few times already last year.but after i press reset gfi breaker wait 15second.my machine can use again.but this times machine still remain no display.can anyone know this problem?thank you
  • shinchan
    • May 2011
    • 195
    Re: xerox dcciii 3300 cant turn on
    Originally posted by alaneong2923
    hello everyone,
    try cleaning RAM gold contact point. i usually rub both side of the gold contact point using eraser.
    • GIUBOSS
      • 1403
      hello everyone,
      you checked if there is a good power line
      • copytech200X
        • 264
        pls check 3.3 v power supply located rear of machine ..there are 3 types of vertical small sizes power supply range 3.3 v to 5 v
