can can the speed for this type machine ??
DCC 250 convert to DCC 450
g'day,mate you can send your DCC250 for speed upgrade to 450 and for dcc320 meter reset to zero counter.you be saving on transportation.Southern malaysia to West port is RM300.00 and Rm300 return.if you come by own transportation,from Tuas,Singapore is about 360km.A 4.5 hour journey at a constant averaging 90 km/h.Highway toll charges about RM50.00 per trip.No a high price in Malaysia.Buy my parts in singapore.CheersComment
Really can be converted dcc250 to dcc450? How it can be done? can it be share?
Really can be converted to dcc450? How it can be done? can it be share? Are you a supplier to supply all the used copier. I'm interested dealing with xerox used copier in Document Center FamilyComment
yes, i do agree by changing the ess and mcu can reset the meter, how about the series number? It will be same for those machine has reset the meter? As i know the serial number is password protected? I'm more keen in speed conversion, as some of the member say by changing the ascii code, but how? it also block by special administration password?Comment
when u replaced MCU and ESS pwb at the same time ,removed existing meter counter(8 pin IC) to another pwb.then meter reading still remains same after u chg new pwb.Comment
