DocuCentre - V 4070
  • Celestina
    • May 2020
    • 7
    [Error Code] DocuCentre - V 4070
    Hi,
    I would like to know about the error code 093-312 for DocuCentre-V 4070.
    Your response will be much appreciated...
    Cheers,
    Celestina
  • GIUBOSS
    • 1431
    Re: DocuCentre - V 4070
    replace the toner or clogged toner dispenser, auger assembly or transport tube.
    • GIUBOSS
      • 1431
      please let us know if you solved it and how, thanks. Regards
      • Celestina
        • May 2020
        • 7
        Yes I have solved it, by firstly replacing the toner, checked the toner dispense motor and the transport pipe blocked. I found that because the machine was not being used for quite a while the toner was solid. So I, vacuumed them and did a test run with a new toner cartridge and drum cartridge and it worked perfectly okay. Thanks much for the help...
