XEROX 6510 list NVM, temperature of the fuser!!!
+ More Options
Posts
  • servismen11
    • May 2020
    • 8
    hi friends, please tell me how to print the list of NVM xerox 6510? can someone tell me how to raise the temperature of the fuser dC131 NVM Read / Write?
    Re: XEROX 6510 list NVM, temperature of the fuser!!!
    what problems are you having?
    what are the page counts of supplies/service parts?
    are you using genuine oem supplies?
    do you have a service manual/pws?
    are you trained on this model or any xerox model?
    • servismen11
      • May 2020
      • 8
      The problem is that the toner does not burn to 200 grams of paper,the toner is erased with a finger, the client took a printer specifically for printing projects on thick paper. Xerox Colotech+ 200 paper, original Xerox toner, service manual for xerox 6510 is available, but there is no NVM sheet to raise the temperature of the fuser.
      • servismen11
        • May 2020
        • 8
        PWS no, I am not an authorized service center!!!
        did not pass training(
          How many pages on the fuser?
          ASSuming this is a print job, what weight/type of paper is selected in the page profile?
          Does it match the paper tray profile?
          Usually if the paper isn't defined properly this is the end result (ASSuming the fuser is in good condition)
          • servismen11
            • May 2020
            • 8
            I use tray 1, put stickers and other paper in the printer's print settings, raised the temperature of the fuser to 6, the toner does not bake on paper 200mm! on paper with a thickness of 150mm, the toner holds up normally! On the printer there is no possibility to set the settings for the paper type cardboard, only in the driver, the temperature of the fuser can not be raised through the usual printer menu on cardboard 160-220mm! The printer is new, just a month old, the authorized service center refuses to help with this problem, they say so and goes from the factory, although the manual says that the printer supports printing on cardboard 160-220 mm!
              and you STILL haven't mentioned WHAT the driver is set for... glossy labels are a tougher issue.
              • xcopytech
                • Aug 2006
                • 1792
                You must set up tray for that paper.
                Read user guide.
                  Read user guide.
                  But But But he says that cannot be done! He should turn this over to someone qualified to handle the simple shit.
                  • servismen11
                    • May 2020
                    • 8
                    the driver has stickers installed, put different settings, you can put cardboard in the driver, but you can't put it in the printer, so it gives an error when printing
                    • servismen11
                      • May 2020
                      • 8
                      Read user guide.
                      the user's manual has studied, trays have exposed, it does not help, as I did not try but on paper with a density of 200 the toner is not baked as it should be, you need to take it through dC131 NVM Read / Write, but I do not have NVM
                      • servismen11
                        • May 2020
                        • 8
                        I would be very grateful if someone could tell me NVM cells on xerox 6510
                        • xcopytech
                          • Aug 2006
                          • 1792
                          There is no dc131 adjustment for phaser 6510 printer.
                          Only thing you can do is to adjust paper type for trays or to replace fuser.
                          I assume that customer use original toners.
                            yes original toners..
                            and we have told him no NVRAM settings to change...
                            he won't listen.
                              For all brands .. cardboard should be run from the MANUAL FEED tray.
                              Anyways I'm done here.
                              Your on your own due to the fact you just won't fucking listen.
