Fiery for DC250 not working
  • tomson25
    • 104
    [Electrical] Fiery for DC250 not working
    Hi,
    My external fiery for DC250 is not working, is there any way to connect machine directly to network ,on the machine side there is one Ethernet and USB port,please advice
    thanks
  • xcopytech
    • Aug 2006
    • 1792
    Re: Fiery for DC250 not working
    No
    Usb port is for diagnostic.
    Ethernet is scanner port
    • Caffeine
      • 391
      No, the DC250 does not have any built-in printing functionality. On this particular lineage of machines (DC240/250 > DC242/252/260 > C550/560/570 > C60/C70 > C9065/C9075), it was not until the Color 550/560/570 series that they implemented the option of a built-in print function.
      The "enhanced" version of this family (DCP700/700i, DCP770, C75, J75, V80/180) never implemented the option. They all require a print server.
      The WorkCentre versions of the DC240/250 had their own options. The 76xx series didn't use a Fiery print server, but did still require a Xerox print server to print (or even boot up -- they can't be copy only machines). The 77xx series built this Xerox print server internal, and also had the option of a Fiery print server on top of that. Once the Color 550/560/570 came out, with its built-in print option, the WorkCentre version was retired.
      You'll have to repair your Fiery. Until then, you have a copy (only) machine.
      • Detonation
        • Feb 2010
        • 404
        Yep, Caffeine summed it up perfectly. What's the issue with your Fiery?
        • Ex-x-tech
          • Jun 2020
          • 3
          Hi,
          thanks
          Unplug the Fiery from the RJ45 jack on the DC250, and replace it with cable from your network. Go into admin settings and configure the ip address, etc.
          Had same problem on a C60 recently and configured network for DHCP. Restarted printer and the network configuration populated and was able to send jobs like it was a desktop printer. Of course, you have to add that printer to you Windows printers and maybe download the driver from Xerox.
          • xcopytech
            • Aug 2006
            • 1792
            If you are xerox tech then you should know that it is not possible to print on xerox dc240 without fiery.
            C550 and C60 have internal print conroller so it is possible to print on them without fiery
            • Caffeine
              • 391
              Plus I literally just explained that, in detail, two posts above... haha
              • Ex-x-tech
                • Jun 2020
                • 3
                Unless it has the Ethernet interface card installed. BTW, I am a Xerox tech.
                • xcopytech
                  • Aug 2006
                  • 1792
                  Ethernet port on dc250 can not be used for printing.
                  • Detonation
                    • Feb 2010
                    • 404
                    The ethernet interface card is for transferring scans only. The DC250 does NOT have on-board RIP capabilities.
                    • Ex-x-tech
                      • Jun 2020
                      • 3
                      I was basing my response on info in the Document Centre 400/350/250 User Guide, section 2.2 where the procedure for installation is described. In part, it states "If you want to use the Ethernet interface, you need to install the optional interface card (100Base-TX, 10Base-T or 10Base-5) first. This section explains the procedure for installing the Ethernet interface card and for connecting by the Ethernet interface."
                      I downloaded the manual from FujiXerox.
                      Maybe it's not applicable to USA machines..... and since I've never worked on this box, the original response to my post may be correct.
                      • Detonation
                        • Feb 2010
                        • 404
                        Typically by DC250 we mean DocuColor 250. I don't think anyone discusses those dreaded Document Centres
