xerox 700 045-360
  • lion_heart
    • Jun 2014
    • 174
    xerox 700 045-360
    Good day, hope all is well, seem to be getting this 045-360 error code of my 700 a lot, running external Fiery, I restored my fiery server, hoping that was the cause but same issue. and the RAP gives such a vague description of the error code. any help would be appreciated.
  • InterfaceP
    • Jun 2013
    • 488
    Re: xerox 700 045-360
    Do you have a External or Bustled Fiery and do you have another of either?
    • lion_heart
      • Jun 2014
      • 174
      This machine is External Fiery, I do have an integrated as a backup, and my creo for next machine went down waiting motherboard for that this week, so would have Creo also
      • Detonation
        • Feb 2010
        • 392
        xerox 700 045-360
        045-360 is related to the ROS (laser unit). Could be the flat cables (most likely), or laser M,Y or MCU.
        • CopierTechofOmens
          Agitating Artificer
          • 268
          • Reseat the interface cable between the DFE and the IOT
          • Refer to the latest Software Release Notes to ensure that the latest software level located in the software matrix is loaded in the machine
          • Reseat the VSEL PWB into the Backplane PWB
          • On Fiery Bustled or EX700 Controlers ensure that the interface PWB is P/N 116N00264 or newer. Replace as required
          • On FFPS Controllers ensure that the interface cable is the 3M Cable with metal connectors (117K44230). Tighten the connectors with a screw driver.
          • On FFPS Controllers ensure that the XIMM PWB is 960K51691 or newer
          • Check that the flat cables are securely connected to the YM ROS and the MCU PWB
          • Install Tag 3 VESL PWB
          • Replace the Flat Cable
          • Replace the YM ROS
          • Replace the MCU PWB
          sigpic
