Dark Lines in Black only
  • disciplepress
    • May 2019
    • 7
    Working on a Xerox 700i, there is an issue with the black in which the lines are dark as opposed to a lighter line which I see often. I replaced the drum, developer, IBT belt, and cleaned the ROS. Nothing changes and again only in the black. Any advice?IMG-3573.JPGIMG-3572.JPGIMG-3571.JPG
  • disciplepress
    • May 2019
    • 7
    Re: Dark Lines in Black only
    Please also see the attached photo. Is this a ROS issue? Again I have changed the developer, drum, IBT, Fuser and cleaned the ROS. The issue is only found in the black.
    • disciplepress
      • May 2019
      • 7
      No help on this??
      • Flash
        • 378
        Looks like a problem with the charge corona.
        • Detonation
          • Feb 2010
          • 410
          I'd replace black drum and if that doesn't help, 2nd BTR is likely. Yeah I know, you'd think it would affect CMY as well, but I have had this issue a few times as well.
          • MrBafner
            • Apr 2011
            • 61
            Did it fix the problem when you changed the 2nd BTR ?
            I'm having a very similar issue, but my image is fading in the center and darker on both sides. Have done the exact procedure you have done and nothing.
            • Dech
              • Aug 2014
              • 48
              Its your ROS. had this problem. cleaned the ROS. stayed the same. opened the ros and cleaned it agian. same. replaced the ros unit. problem solved..
              • MrBafner
                • Apr 2011
                • 61
                Thankyou so much for the reply. Have cleaned the laser .. you think I should replace the laser?
                Have put in a brand new developer units, I was certain that was the problem.
                Only other thing that I can think of is the toner isn't dropping fast enough into the shoot, going into the developer unit.
                • adriansto
                  • 2392
                  Black was faint and patchy with random strobe bands.
                  Cause:
                  Black drum module not connecting to HV connectors correctly.
                  Solution:
                  I had changed the dev tank and the drum module to no avail. All voltages were correct when measured in diagnostics. The Charge voltage fluctuated when taking prints.
                  I checked the connectors, they were all clean and in good condition.
                  I saw that the Gasket that sits under the K drum module at the rear was missing.
                  PL 6.6 Item 22
                  This shows on the EDOC as non spared but is now a Vankit Item Part No. 035E72821.
                  I replaced this part and the fault was rectified.
                  This 'Gasket' is a small grey foam pad that sits on the bottom of the Xerographic Developer Drawer under the K Drum Module at the rear left hand side.
                  The underside of the drum module rests on this and appears to either raise the module to a contact position or to reduce vibration.
                  If you want to selservice this machine it is good ideea to have pws with edoc and bulletins. There are a lots of bulletins about black problems.
