Xerox C75
  • cpress
    • 37
    Xerox C75
    Continuing saga again 061-340 code, replaced c,k ros unit same thing again. Flat cables maybe? Interlock switch seems to be ok.
  • cpress
    • 37
    • InterfaceP
      • Jun 2013
      • 488
      Re: Xerox C75
      Try replacing the K Drum first, but while you have it out check to see if the earth pad is there. Its a small pad to the rear and left. It should be visible when you remove the drum.
      • cpress
        • 37
        Re: Xerox C75
        Put a new one in, cleaned the pad also
        • Detonation
          • Feb 2010
          • 403
          Re: Xerox C75
          Flat cables are usually the problem, plus they are super tricky to re-attach as well. MCU PWB would be next up.
          • EAHG
            • Jan 2020
            • 20
            Re: Xerox C75
            Flat Cables. make sure its seated properly after replacing and take extra caution when returning it back as the flat cables easily comes off or loose contact when repositioning, its very tricky.
            • elsab
              • Dec 2007
              • 63
              Re: Xerox C75
              Might be a problem with front cover interlock or with Xero/Deve Drawer assy connector loose contact. It happens on to previous model similar engine with C75.
