7120 xerox ps enablement
  • dtrevatt
    • May 2020
    • 9
    Hi All, could anyone PM me a enablement code for a xerox 7120 copy centre postscript option, I had the codes but lost them (chip is installed!) thanks in advance
    Re: 7120 xerox ps enablement
    Originally posted by dtrevatt
    Hi All, could anyone PM me a enablement code for a xerox 7120 copy centre, I had the codes but lost them thanks in advance
    what exactly are you try to do?
    what the hell are enablement codes?
    are you a certified tech?
    • dtrevatt
      • May 2020
      • 9
      Thanks for your lovely reply, I am after the feature enablement code (lost!) to enable the postscript option - the postscript chip is installed just need to activate it again. Thanks if you can help and answer to your question I used to be a tech few years ago but doing a favour for a animal shelter with a second hand machine
      • Detonation
        • Feb 2010
        • 410
        Go here:
        Xerox Software Activation Portal
        Click on 'Find an exisiting key'
        Click on '(or enter a serial number to get all the keys for a machine)'
        Enter machine serial number and you are all set.
        • dtrevatt
          • May 2020
          • 9
          Thanks buddy but I think machine is too old as it says not in database thats why I need a code sent to me
          • Detonation
            • Feb 2010
            • 410
            A crap, that's too bad. I've had 7120's in that database if I remember correctly. Sorry that doesn't help.
            • jhalfhide
              • Apr 2015
              • 454
              71 series should be chip only, no codes. Codes replaced the chip in the later 72 series.
              If the chip is in, print a config and see if it states Postscript is installed.
              On the 72 series, you can never lose codes as you go to Xerox FIK page and enter the serial to retrieve all applied license keys
              Sent from my LYA-L09 using Tapatalk
              • dtrevatt
                • May 2020
                • 9
                jhalfhide
                thanks so much for your reply I didnt know that with 7120 - my experience is all canon and richo, DOC.PDF here is the config report. is there any option to enable the port or something then or is it suggesting faulty chip?
                thanks
                d
                • jhalfhide
                  • Apr 2015
                  • 454
                  It should be a case of fitting the chip and installing the PS driver. That's it.
                  What's showing under 'Installed Options'?
                  • dtrevatt
                    • May 2020
                    • 9
                    Installed options look like the attaced on mine, I am wondering if this chip is the right model or is simply not working really appreciate your time!
                    instopt.pdf
                    • jhalfhide
                      • Apr 2015
                      • 454
                      [ATTACH]45898[/ATTACH]
                      That looks right to me. It's PDF enabled I think. We don't have any more of those in the field anymore so can't 100% check but memory says that's it
                      • Detonation
                        • Feb 2010
                        • 410
                        I should have several of these lying around but can't find them right now. PostScript is definitely not enabled, so I think your ROM is faulty.
                        • dtrevatt
                          • May 2020
                          • 9
                          Hey if you do manage to find one model 497K04750 and want to sell one please let me know - keen to locate one asap!
                          thanks
                          dan
                          • Detonation
                            • Feb 2010
                            • 410
                            thanks
                            dan
                            • Jack79
                              • Jul 2014
                              • 312
                              Try reinstall rom. I have seen many times when it was not inserted fully. Do not remember where but it should say installed between position 10 and 14.
