altalink c8045 too much yellow
  • apcrap
    • Jun 2010
    • 25
    I have a c8045 with too much yellow saturation so far I replaced yellow dv assy , swapped out drums and updated firmware . I performed a copier/system nvm initialize only no change if run the procon dc 937 yellow has a fail . The only work around is to reset print calibration than it works for a day if I try to calibrate than there is too much yellow .I'm thinking something with the yellow patch I ordered an LPH , bcr hvps and the dv hvps .
  • Welsh Wizard
    • Sep 2021
    • 7
    Re: altalink c8045 too much yellow
    Hi.
    I have exactly the same problem. Did you find a solution?
    • chubblies
      • Jun 2011
      • 155
      Did you enter the TD sensor ID setting into diagnostics? and set up the dev correctly? You must do this or it over/under tones the dev.
      • xcopytech
        • Aug 2006
        • 1794
        What is machine software level
        • Welsh Wizard
          • Sep 2021
          • 7
          Hi.
          Machine is on the latest firmware as of 10-12-23, no parts have been changed to cause this issue. Resetting Print Calibration makes the issue go away for a few days but it comes back.
          Internal prints like the Demo Page and Supplies Status Page print perfectly, the Copy & Print calibration sheets print out saturated in yellow.
          I suspect either the SBC or Yellow LPH unit
          • xcopytech
            • Aug 2006
            • 1794
            When get print with yellow background do you have white margins on it
            • chemicalx50
              • Apr 2014
              • 39
              Anyone found a solution to this? I am having the issue and can't find a fix
