Image problem V C5585
  • kunaraja
    • Nov 2009
    • 9
    Please help....
  • EAHG
    • Jan 2020
    • 20
    Re: Image problem V C5585
    things to check.
    IBT belt
    IBT cleaner
    Fuser
    Developer
    would be also helpful if you could provide some insights on the FIP you've performed as well.
    • copier tech
      • 8156
      Originally posted by kunaraja
      Please help....
      Start with basic troubleshooting.
      Run that print again stop the machine mid run check the image on the belt, how does it look?
      However from your sample looks like your fuser is the causing this issue.
      • Eagle
        • Mar 2010
        • 49
        Problem definitely in IBT unit. As its affecting all colours and smearing image.
        The image is getting smeared off before the fuser. That is why its has more solid colour at the leading edge and is wiping off to the rear of the trailing edge.
        Remove the IBT unit and check the Ibt cleaner for for paper of obstructions.
        • copytech200X
          • 264
          chk ibt cleaner assy especially ibt blade both screw tight correctly ?
          • Eagle
            • Mar 2010
            • 49
            Every screw must be tight. And make sure the ibt cleaner assy in clipped in correctly and the rear before inserting in machine.
