Xerox 7970i - No display, all lights solid, error code 5
  • Fabiha
    • Jul 2025
    [Error Code] Xerox 7970i - No display, all lights solid, error code 5
    Hi, and thanks in advance for any guidance. I have a Xerox 7970i, and it is no longer working at all. Specifically, the display is blank/off, and all lights are on solid. After several power cycles/reboots, I looked on this forum and followed advice to see what the error code near the ethernet port shows. That display shows number 5. If my understanding is correct, that indicates a corrupt SD card.
    What do I do from here? Is there somewhere/someone from whom I can get an image? I don't have a service contract on this printer, and I have not yet attempted to contact Xerox. Please advise if I need a new SD card, if it has to be one from Xerox (or can I get one locally and format it?), and where I can get the necessary image.
    Also, is there a service manual that would indicate where the RAM is, just on the off chance that that might be an issue/secondary issue? I have DDR2 SODIMMs available; just haven't taken the printer apart to see where it goes.
    Thank you!
    Fabiha.
  • GIUBOSS
    • 1435
    Re: Xerox 7970i - No display, all lights solid, error code 5
    Thank you!
    Fabiha.
    Try booting with the doors open. Then try to release the ram to clean the contacts (ethernet cables and power supply disconnected).
    • MLB759
      • Jun 2020
      • 2
      The death code 5 is usually the SD Card on the SBC unit. You have to order a new one through Xerox due to the format of the card. You will need to replace the card and then do a ATLBOOT reload via USB with current software. Part number for SD Card: 237E28146
