Xerox DC252 error code 091-311
  • mshabban
    • Jan 2017
    • 101
    Hello guys ,hope yo all safe and well, am having trouble woth a xerox dc252 showing 091-311,i have replaced the charge coroton,replaced new black drum,i have also replaced the pre-clean motor assy from behind ,i am now abit stuck ,any ideas will be much appreciated,thanks
  • knightfall
    • Jul 2006
    • 633
    Re: Xerox DC252 error code 091-311
    sorry I don't remember dc252 having that fault code I remember that 91-310 is a waste auger is blocked but they usually group faults together is same area of copier. May want to double check the fault.
    Get your facts first, and then you can distort them as much as you please.
    • xcopytech
      • Aug 2006
      • 1792
      Did you check CC cleaner motor from diagnostic
      • mshabban
        • Jan 2017
        • 101
        Yes ,i did check the cc cleaner motor ,i even had to change it from a working machine but all invain,error code is still on , just wondering if theres a reset procedure i can do ,pliz any idea is most welcome.
        • mshabban
          • Jan 2017
          • 101
          Problem solved ,thanks to everyone who tried to help, now the reason why the machine was declaring 091-311 is because the CC motor sensor was not being powered ,its cabled had been broken.fixed it and now machine is very fine.
