Error code b0 on Xerox DocuColor 252 bustled Fiery RIP
  • Detonation
    • Feb 2010
    • 420
    Does anyone know what error code b0 (maybe: 60) on the bustled Fiery for the DC252 means? I don't see the particular code in the Fiery service manual. The Fiery is non-functional, and I can't seem to re-install software by either USB-stick or CD's.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Error code b0 on Xerox DocuColor 252 bustled Fiery RIP
    Check memory
    • Detonation
      • Feb 2010
      • 420
      Did the trick. Thanks a ton!
      • kendod27
        • Mar 2019
        • 9
        Sorry it's an old post but you didn't state how you fixed it?
        Did you replace memory, reseat memory or something else?
        • Detonation
          • Feb 2010
          • 420
          If memory serves my right (haha) I replaced it
          • kendod27
            • Mar 2019
            • 9
            That's good enough for me, will give it a try as your thread is the only 1 I can find with same issues and code. Thanks
            • Detonation
              • Feb 2010
              • 420
              Hope it works! Post back here with the results.
              • adriansto
                • 2397
                Be sure you dont have scan cable into network port of Fiery.
                • kendod27
                  • Mar 2019
                  • 9
                  Cables should be all correctly fitted but it's a good shout to double check them anyway to be sure as I did have the cables off
