various 061 error xerox 700
  • lion_heart
    • Jun 2014
    • 174
    Good day, xerox 700, was getting 045-316 for a few days, was able to restart machine and would go away, today would not go away, so reseated the ROS cables, now strangely I am getting 061-380, no idea what that is, any assistance would be great.
  • fugglefeet
    • Jun 2020
    • 34
    Re: various 061 error xerox 700
    061-380 RAP
    ROS Data Failure Yellow. Serial data communication is not possible between the MCU PWB and ROS (hidden failure).
    Perform the following:
    Ensure that the Flat Cable connectors of the ROS Assembly (YM) and the MCU PWB are connected correctly.
    Check the connectors on the YM ROS and MCU PWB (PL 11.1).
    Reseat the NVM PWB on the MCU PWB.
    Replace the Flat Cable (PL 5.1).
    Replace the ROS Assembly (YM) (PL 5.1).
    fugglefeet
    • lion_heart
      • Jun 2014
      • 174
      Thanks a million. reseated many times, didn't work, ordered new ros cables hope that works before buy new ROS
      Originally posted by fugglefeet
      061-380 RAP
      fugglefeet
      • Caffeine
        • 391
        I know you said you already tried several times, but as you know the ROS cables on these models are worse than a nightmare. Be super methodical when you go to replace them with the new cable to make sure it isn't just because the cable is being a jerk.
        And don't forget to plug in the little power cable above the back of each ROS after you replace the flat foil cables. I mean, not that anyone would EVER forget that... 😇
