fuser system error
  • Reeves
    • Apr 2012
    • 277
    [Error Code] fuser system error
    Hi everyone
    i have a xerox wc 7845 displaying fuser system error with error code 310-381 fuser unit no heating up fuser thermotor fail
    what i have done so far
    - changed the fuser unit
    - systems software upgrade
    - system reset
    - fuser life reset
    - set nvm 616-014 to 2
    - set 744-001 to 0
    when i reset the fuser unit life its not resetting to 0 the counter for the fuser unit is showing 217,483,647 and total no of copies on the machine is 64,762
    what could be the problem pliz help
  • copytech200X
    • 264
    Re: fuser system error
    kindly check fusing assy chip and change back existing machine chip then problem resolved
    • Reeves
      • Apr 2012
      • 277
      Does this fuser unit has a chip??
      • copytech200X
        • 264
        yes ,open torx screw at the rear fusing assy and reinstall existing machine chip to new fusing .
        • weetu
          • Jun 2020
          • 12
          Perhaps there is a chip because HI and LOW speed fusers are not interchangeable, the low speed part no. end with 220 and hi speed ends with320.
          In addition, the machine says "This is not a proper fuser" or something similar.
