Xerox Workcentre 7120
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    I'm a Ricoh technician, so excuse me my - perhaps - stupid question:
    There is a bleu smear only on color printouts.
    Customer says he recently has replaced all pcu's, F.U. and transfer belt.
    He only uses original Xerox products.
    Is there a simple solution?
    Thanks in advance
  • GIUBOSS
    • 1437
    Re: Xerox Workcentre 7120
    Originally posted by Mark Bbb
    Hoi,
    Thanks in advance
    going to exclusion, the cyan developer remained
    • Jack79
      • Jul 2014
      • 312
      Probably Cyan R2 Drum Unit. Part number: 013R00660. Make sure the LSU for cyan is cleaned too.
      • Mark Bbb
        • Jun 2012
        • 1662
        Thank you for your help.
        The cartridge is it the developer unit and the pcu together?
        • copytech200X
          • 264
          yes ,it's comes with drum and developer unit in one set.
          • Jack79
            • Jul 2014
            • 312
            When you said transfer belt replaced I understand a whole unit was changed. If not then disassemble ITB unit, check and clean metal roller under the belt.
            Drum R2 unit is a one part (developer + drum)
