Xerox C70 keeps melting fusing lamps causing 010-334 codes
  • vandel
    • 5
    [Error Code] Xerox C70 keeps melting fusing lamps causing 010-334 codes
    I have a Xerox C70 that will melt the fusing lamps causing 101-334 codes. I can replace the fuser and it last a month....maybe.
    Re: Xerox C70 keeps melting fusing lamps causing 010-334 codes
    OEM fusers?
    • vandel
      • 5
      OEM fusers?
      They have all been OEM fusers.
      • azehnali
        • Nov 2009
        • 679
        are they running anything special as far as paper
        have you checked the line voltage also
          • 16333
          That's a thermistor code. That lamp should cut off long before it goes into meltdown mode. Normally on most fuser circuits there's a thermal breaker that will trip and apparently that isn't working, either. Very dangerous.
          Edit: My guess is that you've got a board problem that's not telling the lamp to cut off when it reaches temperature. The AC voltage to the fuser is usually controlled by a TRIAC being switched on/off. The TRIAC can usually be found on the AC circuit board. The TRIAC normally receives a control signal from the Main PWB. Sounds like you have a bad board or a pinched wire.
