Xerox WC 7830 Developer change
  • LATechnico
    • Jan 2017
    • 21
    Hi guys,
    I have a Xerox WC 7830i that was over adding and dumping Cyan toner. I've decided to change the developing unit and developer. Do I need to run a set up procedure for new developing unit? Or should it print ok without a set up. Not familiar with Xerox, any help is greatly appreciated!
    Re: Xerox WC 7830 Developer change
    Originally posted by LATechnico
    Hi guys,
    any xerox I have worked on yes you need to run an init setup.
    do you have the manual? NEEDED FOR WORKING ON THESE POS's
    • LATechnico
      • Jan 2017
      • 21
      Haha, thanks for the reply. Just downloaded the manual, hopefully the info is there. Business is still slow so not turning down any work even if I gotta deal with some headaches!
      • weetu
        • Jun 2020
        • 12
        Hi guys,
        You have to go to Diagnostics and enter the ATC (Automatic Toner Control) value in the system. Normally it is somewhere around 50. The value is the ATC sensor's value got at manufacture and it is unique to the sensor which comes in the new Developer Assy.
        You will find the value printed on a small sticker attached to the bottom of Developer housing. Write it down for further use.
        The machine will run with wrong value however, but if you really need good color balance you MUST enter the value and run the setup routine. Otherwise you'll finally end up with the dumping issue.
        I suggest you check first the present value if it is terribly wrong.
        Good luck.
        • LATechnico
          • Jan 2017
          • 21
          Good luck.
          Awesome info, what's the procedure for accessing the diagnosis mode?
            it's in the damn MANUAL! you shouldn't be working on ANY Xerox box without one!
            • LATechnico
              • Jan 2017
              • 21
              Well! What do we have here? A ___ comedian? Haha
              I do agree with you Phil B, I'll definitely be looking up the manual when I work on this beautiful machine.
                not a comedian AH.
                I have been working on Xerox crap for the past 28 years...31 years total in the industry. they are getting more difficult to work on AND impossible without the manual and PWS.
                put in a manual request here: https://www.copytechnet.com/forums/s...nual-requests/
                but don't worry you won't have to deal with the comedian any longer.
                • LATechnico
                  • Jan 2017
                  • 21
                  not a comedian AH.
                  Thanks Phil. I started on Minoltas back in '92 myself but rarely work on anything bigger than a desktop for the last 15 years. I've tried other business but the printers are still my bread n butter.
                  Are you retiring? Or changing industries?
                  • weetu
                    • Jun 2020
                    • 12
                    Press and HOLD <STOP> button for 10 seconds. Then enter 6,7,8,9.
                    The machine has to be in normal copying state eg. Services, E-Mail etc. visible on the touch screen.
                    Don't reset anything while in Service Mode. You just want to enter the ATC value, eh?
                    GL
                    • Detonation
                      • Feb 2010
                      • 410
                      GL
                      Haven't checked if that works, but AFAIK you should press on hold the 0 button for at least 5 seconds, and then, while you keep holding it, press the green start button. Then it will ask you for a code, which is 6789. Then, the diagnostics menu will be unlocked from the utilities (common settings)
                      • LATechnico
                        • Jan 2017
                        • 21
                        GL
                        Yeah, either calibrate the new sensor or enter the value it should be set to.
                        Thanks!
                        • LATechnico
                          • Jan 2017
                          • 21
                          Thank you, I will post a reply with results.
                          • weetu
                            • Jun 2020
                            • 12
                            Thanks!
                            Yes, the right procedure is to press ZERO (10 secs), the START and 6,7,8,9
                            As I do this daily its is so automated that I gave wrong advise, sorry.
                            • Scarecrow
                              • Oct 2010
                              • 234
                              Hi guys,
                              Lat, Non OEM toner will cause that. If you replace the housing with carrier that came from OEM toner, and use OEM toner there after, you will be good to go. The waste auger for the cyan drum may also have a problem.
