I have a problem with a xerox 560, the toner rubs off heavy papers when i print full black or full colored , i change 3 fuser and the problem is the same, i searched over the web and the xerox site also but i don't find solutions. I have a xerox 560 with fiery rip.
Toner Rubs Off xerox 560
Re: Toner Rubs Off xerox 560
sounds like you don't have the paper type set to heavy -
I also think it's too much toner, and fuser can't melt it. There were NVM settings for fuser ghosting, you should try it. I believe that is where you adjust 1st Btr's, so they transfer less toner and it can be fused properly.Comment
do you mean you are putting no toner on the page.. basically feeding blanks?
is there moisture in the paper?
if the paper has moisture in it there can be all SORTS of problems.Comment
