Xerox 5775 scan to email problem
  • mrfuser
    • 1617
    Anyone ever seen where the first one or two scans to email work fine then after that they always say there is a server error? We put the password in again and it works 1 or 2 times then same result. Any thoughts?
    thanks all!
    k
  • shinchan
    • May 2011
    • 197
    Re: Xerox 5775 scan to email problem
    make sure dns is correct
    if machine ip address is using dhcp. then dns should be automatically
    if ip is using static. then enter the dns as the same as your gateway address (main router/modem address)
    • mrfuser
      • 1617
      Correct. They had the wrong dns and insisted it was correct. I found correct and changed it
        • 30234
        Always double check the network settings
        • mrfuser
          • 1617
