Xerox HDD wipes
  • emujo2
    • Mar 2017
    • 1579
    [Misc] Xerox HDD wipes
    I been asked to format HDDs on Xerox 5335P and 7835..I have never worked on Xerox, these are being replaced by Konica Minolta. Customer wants HDDs wiped by KM befor they leave the offce, but I want to ensure I don't make a huge mistake..
    These machines need to go back to the leasing company, if HDD wipes render them useless (I believe Canon requires software reloaded, but KM does not) I do not want KM to do this. Would anyone be willing to provide the correct way to format these drives? (again not necessary if software/firmware must be reloaded as I have no way of getting it). TIA E
  • jhalfhide
    • Apr 2015
    • 454
    Re: Xerox HDD wipes
    Both devices have encrypted HDD and secure image overwrite on by default. If this isn't enough, perform a forced ALTBOOT as per the manual.
    Sent from my LYA-L09 using Tapatalk
    • emujo2
      • Mar 2017
      • 1579
      Re: Xerox HDD wipes
      Reminds me if the old "you must be an engineer" joke..I have a lot more data, but am no closer to a solution..
      1. I don't have a manual
      2. I need to know if the HDD format will prevent the machine from starting, thus I get a bill from the leaseing company for the machines being dead.
      3. Xerox is similar to KM's bizhub secure that overwrites and encrypts data sent and stored on the HDD, but for some customers the drive must be formatted to a specific standard. This is what I need to do..
      I can probably google the ALTBOOT, but would appreciate the key sequence.
      • shinchan
        • May 2011
        • 197
        Re: Xerox HDD wipes
        if I recalled correctly. do it at your own risk
        the steps are the following
        1. switch off the machine
        2. press and hold number 6, power saver button, and stop button.
        3. turn on the machine ( you may want to ask someone to help you turn on the machine).
        4. for me, i keep holding the button until the xerox logo comes on the screen.
        Here I attach the special boot
        specialboot.pdf
        • emujo2
          • Mar 2017
          • 1579
          Re: Xerox HDD wipes
          Thanks for that..Does the HDD format require any software/firmware reload to make the device operable? E
            • 23008
            Re: Xerox HDD wipes
            Not that I'd know ... but both the HDD Initialize and HDD Format seem to read like they remove only user data and page data, leaving the machine operable. Just my opinion based on the text. =^..^=
            • emujo2
              • Mar 2017
              • 1579
              Re: Xerox HDD wipes
              I agree, but, like in my normal KM world, some customers demand a HDD format to meet a certain securtity policy, or in some cases a DOD standard. Simply running the "erase stored docs" isn't enough. At this point I'm only trying to find out if doing a physical overwrite of the drive requires firmware to be re loaded. I have pretty much decide against it as my simple question doesn't seem to have an answer..E
              • xcopytech
                • Aug 2006
                • 1794
                Re: Xerox HDD wipes
                If you remove hdd from machine and format it you have to reload machine system software.
                  • 23008
                  Re: Xerox HDD wipes
                  Helpful, but as far as I can tell, it still does not answer the initial question. =^..^=
                  • tsbservice
                    Field tech
                    • 8018
                    Re: Xerox HDD wipes
                    Too late probably...anyway Happy New Year and please review this topic:
                    delete harddrive - Customer Support Forum
