xerox 700 077-311
  • David 700
    • Jan 2021
    • 6
    [Error Code] xerox 700 077-311
    Hi New to the site and thank you for any help you could give
    xerox 700 with constant 077-311 error and vibrating from nip roller on warm up
    have replaced with working decurler unit and new one but same errors and vibrations, rails was slightly out of alignment and have been replaced
    any suggestions will be much appreciated, customer losing work after just starting up and trying to help
    David
    Re: xerox 700 077-311
    David
    Fault Code 077-311: Invert Release Failure
    do you have the manual for this unit?
    • David 700
      • Jan 2021
      • 6
      nope fraid not
        nope fraid not
        put all manual requests here: https://www.copytechnet.com/forums/s...nual-requests/
        IMHO anyone that tries working on a Xerox unit WITHOUT a manual is shooting himself in the foot from the jump.
        • David 700
          • Jan 2021
          • 6
          very true, i will request as soon as i possibly can, have to wait 15 days
          has always been in the past replace the unit but stumped with this one
          David
          • adriansto
            • 2387
            David
            Visualy inspect invertor release motor and drive belt.
            • David 700
              • Jan 2021
              • 6
              all is clean free from any toner all been greased up
              there is no reason for this to fail
                have you tested in the SM motor test?
                • David 700
                  • Jan 2021
                  • 6
                  yup 010-011 and 010-012 both vibrate
                  • irdicheku
                    • Aug 2019
                    • 17
                    you can try change the front door interlock, sometimes can solve it.
                    Hope this helps.
                    • David 700
                      • Jan 2021
                      • 6
                      Hope this helps.
                      thank you
                      found the rails was damaged to rear stopping the couplers from locking together
                      David
