XEROX WC 4265
  • bichette
    • Jan 2021
    • 2
    XEROX WC 4265
    hi
    Please I wan thelp to change HDD to my werox wc 4265 printer (step by step ) and if an standard 2.5" HDD can work or not
  • GIUBOSS
    • 1435
    Re: XEROX WC 4265
    Originally posted by bichette
    hi
    Are you sure you have a problem on the hd and not on an electronic card or firmware?
    Found on an old thread:
    p / n: 007N01703.
    Ok, a standard 250GB HDD will work but you will need to format it from the device as described:
    Follow the steps:
    To save the machine settings and templates, ask the customer to export the fax address book, local and group email address books, and then perform a cloning procedure from the web UI.
    Enter diagnostics, GP 1.
    Go to the Format Hard Drive menu:
    4250/4260: Select More Routines> Format Hard Drive.
    4265 - Select Copier Diagnostics> Format Hard Disk.
    The hard drive will be reformatted and the address books and email address templates will be deleted.
    Ask the customer to import the fax address book, local and group email address books, and then install the clone file from the web UI.
    • bichette
      • Jan 2021
      • 2
      Re: XEROX WC 4265
      who to enter to the diagnostics mode
