xerox 700 no black printing k developer not spinning
  • lion_heart
    • Jun 2014
    • 174
    good day, very weird situation. no black printing and developer unit is not spinning. changed to a next developer unit that I am sure is working, still would not spin, changed the developer drive motor to the back, developer still wont spin. I cleared a little piece of developer off of the silver developer roller to test to see if it is running. i ran 093-019 can hear motor running, but the clear mark is still there to prove the developer hasn't spin. Like i said, I have changed developer and drum and developer drive from back of machine
  • xcopytech
    • Aug 2006
    • 1794
    Re: xerox 700 no black printing k developer not spinning
    Change black developer drive clutch on main drive assy.
    • lion_heart
      • Jun 2014
      • 174
      thanks will check that out
      • xcopytech
        • Aug 2006
        • 1794
        What developer drive motor have you changed?
        There is CMY developer drive and motor. K developer do not have motor only clutch on main drive.
        • lion_heart
          • Jun 2014
          • 174
          Yup seems like the one in that machine is bad, see photos attached and it spun the data cable out of place also, thanks will orderGOOD-ONE.jpgBAD-ONE.jpg
          • lion_heart
            • Jun 2014
            • 174
            I guess i was mistaken on parts as this one in the photo is what i had changed with the long shaft that I assumed spins the developerpart.jpg
            • xcopytech
              • Aug 2006
              • 1794
              That is black drum motor
              • Tecnico_Xerox
                • Jan 2019
                • 54
                Hi.
                by chance you checked the gears of the black development unit, many times they wear out and stop making contact with each other
                and the magnetic roller does not rotate
                • lion_heart
                  • Jun 2014
                  • 174
                  Originally posted by Tecnico_Xerox
                  Hi.
                  yes thanks I did, that developer unit is fairly new, and I replaced it to a next new developer unit. xcopytech seems to be correct with his assessment as the black developer drive clutch is broken. ordered it and waiting on arrival, will updated once changed. thanks for assistance
                  • lion_heart
                    • Jun 2014
                    • 174
                    Good day, just wanted to give an update, changed the developer drive clutch and it works again. thanks guys for assistance.
