Versant 2100 error 077-339
  • mercadoven
    • May 2014
    • 22
    [Error Code] Versant 2100 error 077-339
    HI,
    I have a Xerox versant 2100 with error 077-339, error description says, lower cooling belt walking to outer side, and It does, if I take out the assembly and center the belt it works for a while then error comes back.
    Does anybody has info about what could be cusing this or any tip about what to look for.
    best regards.
  • fugglefeet
    • Jun 2020
    • 34
    Re: Versant 2100 error 077-339
    Originally posted by mercadoven
    HI,
    best regards.
    A colleague of mine had the same problem and it resulted in the board receiving the signal from the belt edge sensor having to be replaced. Check if the sensor on the upper cooling belt is identical to that of the lower cooling belt and swap out to test. If the belt still walks out, then have a look at the board as the suspect.
    Hope this helps.
    fugglefeet
    • mercadoven
      • May 2014
      • 22
      Originally posted by fugglefeet
      Hope this helps.
      fugglefeet
      Thanks a lot, I'll check the upper sensor, swap and test, and let know.
      • fatfingers73
        • Feb 2013
        • 219
        Hello,
        My colleagues having the exact same issue on a 2100. Do you remember what the fix was?
        He's on holiday now for 2 weeks so I'll have to pop back there.
