C75 bad prints
  • positiveg
    • Jun 2018
    • 299
    C75 bad prints
    Hey there guys it's been months since we've been able to get a consistent week of prints from the C75.
    It's been one thing or another. Now we are getting these faded looking prints
    Can't pinpoint what it is. We've changed all the colour drums. Think the black drum was new as well but all the colour have been changed since late December.
    Please assist thanks
    Sent from my SM-G955F using Tapatalk
    • 16391
    Re: C75 bad prints
    What do the test charts look like?
    11% ANSI A Color 8.5 x 11.pdf
      Re: C75 bad prints
      looks like bad dev units... bad transfer..or dirty laser glass.
      what are the counts on the unit?
      OEM drums and toners?
      if you do a stop test is the image on belt and drums good or faded?
      you really need to tell us what you have done besides swapping drums.
      • positiveg
        • Jun 2018
        • 299
        Re: C75 bad prints
        [ATTACH]48323[/ATTACH]
        I'll provide you with that print out
        • positiveg
          • Jun 2018
          • 299
          Re: C75 bad prints
          Toners new
          Drums all new drums placed this January
          Black placed in late December.
          I'll get the counts. Not high the printer hasn't run properly since October. Installed new B/C laser unit. The dev units are all but new with the exception of thr black as in all were replaced last quarter of last year.
          The magenta dev unit cover plastic was torn I replaced it but it still spills so I've ordered a full replacement cover due in Friday. Well that dependa.
          But thats it really fuser 89% the only time don't get that heavy fade is black and white.
          • fugglefeet
            • Jun 2020
            • 34
            Re: C75 bad prints
            Hi all,
            Is the white connector on the back of the 2nd BTR plugged in? Is there a toner buildup at this connector? Arcing at this connector or a disconnected connector will result in faded image transfer from the IBT belt.
            Hope this helps.
            fugglefeet
              Re: C75 bad prints
              Toners new
              Pull the dev units..spin the mag roller.. does it get even coverage.
              Letting a unit sit for a while can affect dev units .. belts.. fuser...
              Esp if left powered on.
              Clean all sensors..internals.. run calibrations.
              Post pdfs of results.
              • positiveg
                • Jun 2018
                • 299
                Re: C75 bad prints
                Thanks for the feedback.
                I was wondering about the fact it's been offline for a while. We hadn't had it on much to be honest. Just been using a small Konika unit.
                Bu I'll try what yiu suggest. So you think it may be the magenta. The tech came in cleaned the laser it was ok for about 50 prints then back again. I'm just wondering if it can spill that bad back on the lasers though?
                • xcopytech
                  • Aug 2006
                  • 1794
                  Re: C75 bad prints
                  Clean ROS
                  Check developer covers
                  • zagrex
                    • Dec 2011
                    • 63
                    Re: C75 bad prints
                    Make sure you are using genuine toner in your machine!!!!
                    this problem happens when the original toner is not used.
                    • positiveg
                      • Jun 2018
                      • 299
                      Re: C75 bad prints
                      This issue was messy lasers. Thanks
