Versant press 180 ibt belt motor
  • @RLaggy
    • Oct 2017
    • 5
    [Misc] Versant press 180 ibt belt motor
    I have a Xerox Versant Press 180 machine whose IBT belt drive motor is giving a very noisy sound. When I print a file it give a double images output print. I try to use another motor from another same machine but it still have the same problem. Can anyone pls help me with this problem. Is it also bad to transfer that drive motor to another machine. Thank you.
  • xeroxbg
    • Feb 2020
    • 10
    Re: Versant press 180 ibt belt motor
    Hi @RLaggy!
    Try the following: disassemble the IBT Cleaner and start the printer without the cleaner. If the noise disappears then replace the IBT Cleaner assembly.
    • @RLaggy
      • Oct 2017
      • 5
      Originally posted by xeroxbg
      Hi @RLaggy!
      Hi, I have done that already and it's still having the same noise problem. Now if I will replace the drive motor, would you think there is any technical procedure to follow before installing the drive motor?
      Thank you for your kind reply. Have a good day.
      • xeroxbg
        • Feb 2020
        • 10
        There is no special procedure.
        Good luck!
        • mikimiki
          Hi, i have same problem with my versant 2100. Do you fix the problem?
          • SeniorTch
            • Jun 2017
            • 116
            I recently had a problem in a V2100, error 42-384, motor, encoder disk and sensors, wiring continuity, signal voltages in MCU, everything was fine. in the end I replaced
            105K31670 AC Power Supply
            PL18,4 item 4.
            but in versant 80 /180 I am not sure this circuity is the same.
              different model
              please start your own new thread
              list EVERYTHING you have tried in the 1st post. it'll save time for us 5o ask a Q then to have you come back..already tried that
