Versant 280, i-EFI DOA
  • Rusty.Harris
    • Jan 2021
    • 629
    New install...a week later the fiery crashed big time. HDD doa. New HDD, wouldn't install.
    EFI said that from the screen we had, it sounded like the fiery motherboard was bad, so it
    is on the way. Now, what we WANTED to do, was to get the customer where they could
    just print. We spent hours trying everything to just put in a driver to get it to print, without
    the fiery, but no luck. Tech called the hotline, said it was a known issue that if this machine
    had a fiery, there wasn't any way to make it print. We couldn't even get it to print via a
    thumb drive on the USB port. Ok, what did we miss?
  • Caffeine
    • 391
    Re: Versant 280, i-EFI DOA
    This machine has _NO_ built in print functionality. Through a Fiery is the only way to print.
    The hotline was only semi-accurate. It isn't a case that if a Fiery had been installed, it can no longer print (implying that installing a Fiery deactivates the built-in print function) because there is no print function in any Versant model, to begin with.
    • Rusty.Harris
      • Jan 2021
      • 629
      I guess they changed it from the C60-70. You could print to them without the Fiery. I kind of thought something was up...
      When I set up a C60/70, the interface for the fiery wasn't built into the machine (as I remember?). But, on the 280, the
      board was already connected.
      • Rusty.Harris
        • Jan 2021
        • 629
        • Caffeine
          • 391
          • Rusty.Harris
            • Jan 2021
            • 629
            Well, it's back up and running. The tech that put in the new fiery motherboard said it popped a few
            codes...cm/yk cables connected backwards, couple other things but he did get it back operating.
            Less than 2 weeks old, bad motherboad on the fiery. Oh well, I usually give new things 30 days.
