Xerox altalink 8045 glass
  • efe311
    • Oct 2008
    • 114
    Xerox 8045 if you copy from ADF good copy but if you copy from the glass give me this copy or message that the order delete
    Sent from my SM-N950F using Tapatalk
  • IGEN93
    • Jul 2018
    • 49
    Re: Xerox altalink 8045 glass
    Originally posted by efe311
    xerox 8045 if you copy from adf good copy but if you copy from the glass give me this copy or message that the order delete
    sent from my sm-n950f using tapatalk
    check for the improper belt operation and clean the optics mirror of the scanner carriage , if any contamination found, clean it and apply grease on the carriage slide.
    Make sure all the mirrors are clean also the ccd .
    • efe311
      • Oct 2008
      • 114
      No mirror just carriage and all is clean
      • eunuch39
        • Aug 2014
        • 40
        looks to me like bad scanner cables ir power and data cables 117k50580 and 117k50590
        • efe311
          • Oct 2008
          • 114
          Are you sure did you see this problem
          • eunuch39
            • Aug 2014
            • 40
            YES i have seen very similar issue on c8045 ended up being scanner cables
            • Rusty.Harris
              • Jan 2021
              • 631
              This isn't a xerox fix, but I've had issues with other manufacturers machines that off the glass it was good/bad, but through the doc feed it was
              good/bad...ended up being a bad DIMM memory module. How I found it was there were two ram modules. One for page memory, the
              other for the system. Swapped them and the machine wouldn't boot. Replaced it and it fixed the issue.
