docucolor 3535
  • euro scott
    • 127
    docucolor 3535
    does anyone have the procedure for storing and reseting the nvram on this machine? i have a customer that wants me to install a used main control board. thanx
  • adriansto
    • 2388
    You need a Xerox PWS laptop with 3535 diagnostics program to make that
    • euro scott
      • 127
      there's no internal service mode?
      • xcopytech
        • Aug 2006
        • 1794
        which board you want to replace?
        if you need to do serian number sinhronization must have xerox pws
        • adriansto
          • 2388
          It is a limited internal diagnostics but you need to change MCU pwb.
          For that action you must use diagnostics software from PWS
          • euro scott
            • 127
            ok, thanx for the replies
            • mubtuhogar
              • May 2009
              • 13
              Is there an internal Service Mode to reset the copier to factory default settings?
              • TechMate
                • Mar 2008
                • 285
                You don't just reset a copier machine to factory settings as these were pre-configured to the area of distribution. But if you do, it will reset to JAPANESE factory settings (which you wouldn't like to do anyway - unless you're in Japan )
                If you have any specific problem to a particular machine, just deal with the problem. It will make things much easier
                • WIWA
                  • Mar 2009
                  • 97
                  Hey euro, get out of there if you do not have a PWS this machine requires it for anything (no UI diagnostics) so no spend your time and money there. Just in case I have PWS with 3535 diags.
                  Hope this help,
                  WIWA 72,
                  Gonzos build v.1.0
                  • euro scott
                    • 127
                    Yea- we bailed on this deal as we discovered this issue, had the customer call X direct for this as they bought their own board, but we still do routine maint on it..
                    Thanks for all the replies !!!
