Versant with repeating spot
  • big mike
    • Sep 2012
    • 131
    I have a Versant 3100 with a magenta spot that repeats every 148mm (5.8"). I replaced the magenta drum and it's still there. Any ideas where to check? I need to fix it in the morning and the EDOC hasn't led me to a chart like they have on older models. Thanks in advance for your advice and time.
  • azehnali
    • Nov 2009
    • 679
    Re: Versant with repeating spot
    post a photo
    • azehnali
      • Nov 2009
      • 679
      that distance is the diameter of the drum
      I would swap the yellow and magenta drums
      • xcopytech
        • Aug 2006
        • 1757
        Check this pdf
        • FRAGILE
          • Apr 2021
          • 2
          .6 BCR HVPS Replace the BCR HVPS (PL 18.3)
          1.3 Drum Motor Motor or Drum Drive (PLxx)
          1.9 ROS vibration Replace the ROS (PL 2.1)
          1.6 / 2.0 Developer Housing drives Replace the Developer Housing (PL 5.2)
          2.5 ROS Laser Diode power SW or NVM change, or new ROS
          • SW level xxx.xx.x
          • Replace ROS (PL 5.2)
          4.2 Fuser drives Replace Fuser Assembly (PL 7.1A)
          4 - 6 BCR HVPS fluctuations Replace the BCR HVPS (PL 18.3)
          10 IBT drive components Inspect IBT drive components and replace as required (PL 6.3)
          11.3 Drum Assembly Motor Replace the Drum Assembly (PL 8.2)
          22.5 or 45 Mag Roll in the Developer Housing Replace the Developer Housing (PL 5.2)
          37.7 BCR Replace the Drum Assembly (PL 8.2)
          59 1st Bias Roll Assembly Replace the 1st Bias Roll Assembly (PL 6.3)
          62.8 BUR Roll Assembly Replace the BUR Roll Assembly (PL 6.2A)
          75.4 2nd BTR Assembly Inspect/clean the 2nd BTR Assembly and replace if required (PL 6.8A)
          140 IBT Drive Roll Replace the IBT Drive Roll (PL 6.3)
          147 Drum Assembly Replace the Drum Assembly (CRU) (REP 8.2.2)
          154 Pressure Roll Assembly Inspect/clean the Pressure Roll Assembly and replace if required (PL 7.4)
          208 from LE A smear or band in the IB/OB in a dark image when running heavy weight media Perform IQ18 Smears RAP
          375 from LE Fuser Belt Inspect/clean Fuser Belt Assembly and replace if required (PL 7.4)
          • big mike
            • Sep 2012
            • 131
            Thanks for the replies. It was the drum. Actually, there were two drums effected. One is noe in the yellow position, the other was replaced. I appreciate your support. I am slowly getting up to speed on these.
            It's in a print shop that runs 13x19 gloss card stock duplex. I fought skew issues until I found you can raise the gate fingers (changing nvms), and using the fiery, in SLM advanced, increase buckle (loop), increase pinch roll pressure. It's much better now.
