Xerox C60 Jams at Fuser Exit & Error Code 077-103
Latest Activity
  • Kwaku Abrokwah
    replied
    Hello, please anyone fixed this issue yet? I'm getting the same issue of paper jamming but only on A4 size on Xerox J75 Press. I'm getting these error codes: 077-103, 077-111, 048-100
  • Detonation
    replied
    Re: Xerox C60 Jams at Fuser Exit & Error Code 077-103
    It also helps to check if the problem only occurs when printing (single sided) with printed size down (default), or also with printed side up.
  • marcodm
    replied
    Originally posted by adriansto
    There are multiple reasons for this error:
    decurler assy ( motor ), exit assy drive motor or clutch, fuser exit sensor, dry white plastidip on gears and so on. You must look what others error appear in machine faults history.
    thanks I will check
  • adriansto
    replied
    Originally posted by marcodm
    Any solution to this problem? is the sensor the problem?
  • marcodm
    replied
  • Krojc
    replied
    Have you fixed the problem?
    I have same 77-103 jam on some papers when printing full format (330x488 mm). One gets out normaly, second jams just near fuser rollers.
  • xcopytech
    replied
    Sensor actuator on your pic is not at the same position as on pic I post.
    That is reason for jam.
    Paper do not actuate sensor on time.
  • nickjabbour
    replied
    Originally posted by Exok
    The sensor on the door in the upper right of your photo, check the actuator. Its the part that hangs down into the paper path. The paper needs to push it so that it moves the actuator out of the U shaped part (no longer blocking the sensor). The actuator just snaps into the rest of the sensor and is spring loaded to push it back in place after the paper passes it. It can be very easy for the actuator to pop out on one side.
    I've checked both actuators and they both appear intact, return to their home positions appropriately, and are well seated. I cleaned both sensors, but there was no indication that they needed it.
    The paper stops past the first and just shy of or at the second.
    If I manually turn the rollers outside the door, the paper will feed out, but it is not visible from outside the door.
    I am still getting the 077-103 error. I've logged into the repair menu but cannot figure the chain link codes to check the sensors.
    Do these sensors go bad?
  • Exok
    replied
  • nickjabbour
    replied
    Originally posted by xcopytech
    Fix sensor on right door
    I think that's what it may be.
    Is there a way to bypass temporarily or test in diagnostics or with multimeter?
    Thanks so much.
  • nickjabbour
    replied
    Well isn't there a set of gears on the door you have open?
    Close the door see if those rollers move another set of rollers.
    I've tried it in every configuration: door closed with and without finisher causes jam. Door open does not.
    I suspect it's the sensor inside the door. Curious if there's a way to bypass it for diagnostic?
    replied
    Originally posted by nickjabbour
    Hey, thanks!
    Fuser turns freely by hand when removed.
    Total prints lifetime is 165,000.
    When I open the exit door and manually hold down the door sensor, it sends the paper through with no problem. It appears to be encountering a problem between the fuser exit and the finisher. The rollers at the door do not seem to be firing up, and the clawed paper guides that flip up and down on the inside of the door will sometimes catch in the up position. I'm not sure if they are actuated or not...
  • xcopytech
    replied
  • nickjabbour
    replied
    pull the fuser..check to make sure it turns ..check the sensor in SM for proper operation.
    what are the life counts om service parts.
    Hey, thanks!
  • xcopytech
    replied
    Check fuser exit sensor
