Reseat the black HDMI-cables from the Fiery to the IOT. The cable for the yellow channel is used as a communication cable between Fiery and IOT, if this cable isn't connect properly, the Fiery will reboot after a short while
I double checked the 2 cables, both are good and going from the Fiery to the proper ports on machine, i can print to the fiery but it still won't load the fiery Application on the machine op panel
