Versant 280 Fiery
  • tjvincent
    • 280
    Versant 280 Fiery
    I have the Fiery hooked up to machine but how do you add the fiery application or Icon to the machines panel ?
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: Versant 280 Fiery
    Reseat the black HDMI-cables from the Fiery to the IOT. The cable for the yellow channel is used as a communication cable between Fiery and IOT, if this cable isn't connect properly, the Fiery will reboot after a short while
    sigpic
    • tjvincent
      • 280
      I double checked the 2 cables, both are good and going from the Fiery to the proper ports on machine, i can print to the fiery but it still won't load the fiery Application on the machine op panel
      • xcopytech
        • Aug 2006
        • 1794
        Crossover cable between fiery and machine.
        • tjvincent
          • 280
          Definitely connected otherwise how could I print to the Fiery and it prints out a Fiery config page every time I reboot
          • xcopytech
            • Aug 2006
            • 1794
            Not cable between PC and fiery.
            You must have crossover cable between fiery an versant 280 to be able to run fiery application on machine.
            • tjvincent
              • 280
              Yes grey Gigabit cable is hooked up between fiery and machine.
              • xcopytech
                • Aug 2006
                • 1794
                Set machine ip address to 100.100.100.101
                Subnet 255.255.252.0
                Gateway 100.100.100.102
                Dns 100.100.100.102
                • tjvincent
                  • 280
