Turn off Xerox monitoring or remote services
  • buzz
    • Aug 2013
    • 288
    Hey Xerox techs,
    I'm a Sharp guy 😁, but not so sharp when it comes to Xerox.
    Customer is not renewing their maintenance contract with Xerox. They are asking if something can be done to disable remote services (Xerox Monitoring of equipment).
    How can this be done, if possible?
    Machine is 7855i
    Thanks so much for any feedback.
  • jhalfhide
    • Apr 2015
    • 452
    Re: Turn off Xerox monitoring or remote services
    Go onto web interface and the option is in there to turn it off. Customer can do it no problem
    Sent from my LYA-L09 using Tapatalk
    • XeroxTechBrazil
      • Aug 2008
      • 198
      On any FreeFlow server, open the license manager (Top toolbar, Setup, License)
      Find the license entry for Remote Services, highlight, right click, and when the property sheet opens,, disable the license
      (Radio Button in upper left corner)
      Close out, accept the option to restart if offered.
      License can be re-enabled at any time.
      We used to call it "Xerox Call Home" after the famous line in the movie ET
      • buzz
        • Aug 2013
        • 288
        Thanks so much for this.
        Sorry so illiterate when it comes to X. But...
        Will this affect the "meter toner thingy" on 7845i and 3655, 6655 desktops?
        • jhalfhide
          • Apr 2015
          • 452
          It will affect the remote toner monitoring for Xerox, but as they are coming off contract then that's fine isn't it? You can run your own monitoring tool with no problems, as they use SNMP and that's still running on the machine
          • Murv
            Sr. Escalations Analyst
            • Mar 2021
            • 182
            If it is using metered toners then you will need to swap them to sold toners, or it will choke.
