Apeosport IV C3370 dead / blank because failed firmware update
  • shinchan
    • May 2011
    • 195
    [Dead] Apeosport IV C3370 dead / blank because failed firmware update
    Hello.
    I bought a used copier , Fuji Xerox Apeosport IV C3370 (equivalent to WC 7435).
    I cleaned, vacuumed it, replaced all drums, new toner, new developer+housing.
    It was running great for 2-3 weeks in my workhop (I run independent copier lease/rental).
    One day, when I printed a lot of presentation file (full color) the machine just stop printing and gives me code 041-310.
    I restarted the machine. The machine is ready. When I hit print, immediately paper jam (the tray 1 pulled the paper, but machine stops the paper under transfer roll / BTR Assy). It shows code 041-310 again.
    I looked it up in my manual.
    041-310 IM LOGIC FAIL
    I guess the error 041-310 was due to firmware.
    I load the firmware using USB cable to PC.
    Everything was running smoothly 100%.
    The machine restart once and stuck at the screen 01/06 for an hour.
    I'm guessing something is not right, maybe machine failed to update the firmware.
    SO I thought I can redo the firmware update process by switch it off and turn it on again.
    However, the machine just dead blank after I turn it on again.
    I can't enter download mode, the machine screen was just dead blank.
    No lights in the power saver / interrupt button.
    Anybody had experience with this situation? please kindly share your suggestion.
    thanks in advance.
  • masio
    • Mar 2021
    • 19
    Re: Apeosport IV C3370 dead / blank because failed firmware update
    Originally posted by shinchan
    Hello.
    [ATTACH=CONFIG]49437[/ATTACH]
    thanks in advance.
    Hi,
    i guess your problem is firmware related, what firmware is actually were you using it ? was it for apeos or workcentre ?
    regards
    • shinchan
      • May 2011
      • 195
      Originally posted by masio
      Hi,
      regards
      I used firmware for kisyu (apeos)
      Post launch firmware version 1.104.4
      • Jenks
        • Oct 2021
        • 5
        Hi,
        regards
        If machine is dead see if the circuit breaker above the mains lead were plugged in has popped out its a white square button above the main lead plugs in
        • shinchan
          • May 2011
          • 195
          the circuit breaker above the main power cable is working fine. It has not popped out.
          • njshenking
            • Jan 2022
            • 7
            MCU board is broken and needs to be replaced
            • oscar808080
              • Jan 2023
              • 2
              Hello.
              thanks in advance.
              Is the main power lamp turn on, when your main switch power turn on.
              i have xerox apeosport V C 3375, when it was still load to turn of, accidently I turn on the main power switch, after that i turned on it but fail, no reaction, only main power LAMP.
              Is there any information for this problem
              How about ur machine now
