xerrox 7855 copier when copying and scaner 2 sides
  • cmt
    • May 2019
    • 2
    hi! i have a problem with xerrox 7855 copier when copying and scaner 2 sides .side 2 always get blue background .can you help me ...thanks
    Re: xerrox 7855 copier when copying and scaner 2 sides
    wow talk about no real info.
    what are the lifes on Drums/dev units?
    is it genuine OEM Xerox toner?
    is the machine clean?
    any errors showing on error log?
    when did the problem appear? after service was preformed?
    Phil B. ' The Dentist '
    • cmt
      • May 2019
      • 2
      copy side 1 is still beautiful, side 2 has a blue background, scan pdf still has a blue background, I suspect it's on adf led
      • jhalfhide
        • Apr 2015
        • 451
        That's the little scanner board we refer to as the Pixie board. I think it's actually called PYXIS board
        Sent from my LYA-L09 using Tapatalk
