Xerox D95 and 110 error 72-104
  • bryant28282000
    • Jul 2012
    • 145
    Do anyone know why this machine keeps jamming out of tray 2 with this code? 72-104 Thx!
  • xcopytech
    • Aug 2006
    • 1794
    What did you try to fix it?
    Did you try to switch paper feed unit between trays?
    • Walu
      • 1
      • Paper Path for a foreign object/burr/piece of paper
      • Horizontal Transport Rolls 1 & 2 for dirt/paper particles/wear/a poor rotation
      • Pre Regi Roll for dirt/paper particles/wear/a poor rotation
      • Drive gears for wear/breakage
      • Check for out-of-spec paper
      CC Code to Check
      • [077-103] Pre Regi Sensor (PL 13.16B) (D110, 125, 136 only)
      • [077-103] Pre Regi Sensor (PL 13.4) (D95 only)
      • [077-004] Pre Regi Motor (PL 13.1)
      • [077-002] Take Away Motor 2 (PL 7.19)
      • [077-018] Take Away Clutch 2 (PL 7.12)
      ?Tray and clean the Feed module as well.
      • adriansto
        • 2388
        All time or intermitent jam?
        Only from tray2 or sometimes jam for others trays? Simplex or duplex? A better description of the defect is needed.
        • Murv
          Sr. Escalations Analyst
          • Mar 2021
          • 182
          With that error code? Because the pre-reg sensor hasn't turned on within the specified interval following paper feed.
          Silly question - have you checked the rollers and feed head?
