Xerox Phaser Workcentre 6515 Error 092-321
  • Profibastler
    • Nov 2014
    • 102
    Hello Members!
    There`s nothing to see at service manual about the error message?
    What does the message mean?
    092-312 ATC Sensor fail is exolained in service manual.
    Tried to install new toner, but failed
    Any suggestions?
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    K Patch fail. Developer on imaging/drum cartridge is probably starving due to a clogged/blocked dispense tube. Either that or the imaging cartridge is just defective. My money would be on a blocked dispense tube, though. Have seen it dozens of times.
    • Profibastler
      • Nov 2014
      • 102
      Please explain "blocked dispense tube"
      • Murv
        • Mar 2021
        • 182
        The tube that delivers toner from the dispense mechanism for K possibly has toner compacted in it, restricting the flow of fresh toner/carrier to the developer - which in the case of this model is part of the drum cartridge assembly - thereby decreasing the toner density within the developer (hence the ATC sensor fail) and giving you a low density patch on the ITB (hence the K Patch Fail).
        Your initial post implies that you have a service manual available. Follow the ADC Patch System Fail RAP procedure. Pages 2-331 and 2-332 in the PDF.
        image.pngimage.png?
        • Profibastler
          • Nov 2014
          • 102
          THX, found exploded view at 5-8.
          • Profibastler
            • Nov 2014
            • 102
            Please tell me how to disassembly dispensing tube for black toner and how to check toner transporting. It`s neccessary to remove scanner?
            • Murv
              • Mar 2021
              • 182
              • Profibastler
                • Nov 2014
                • 102
                changed drum BK and working fine. THX Murv
