XEROX 550 ERROR 061-319
  • Apouthe Donald
    • Mar 2014
    • 82
    [Error Code] XEROX 550 ERROR 061-319
    Hello friends
    I have an eureur code 061-319 on a xerox 550
    the Geslock (documentation service) indicates the replacement of the ROS(C,K) and the MCU PWB card
    these 2 elements were replaced without obtaining a result.
    Note: The code is not displayed when the drum black or cyan is removed.
    I really need your help.
  • IGEN93
    • Jul 2018
    • 49
    As on now you have just replaced the ROS cables and MCU , before that you should primarily check the drum units with other machine and also check the interlock operation if necessary change the interlock switch or/if not available open the interlock switch and clean the points of interlock with petrol .
    • Apouthe Donald
      • Mar 2014
      • 82
      Thank you for your reply
      we changed the black and cyan drums initially and we replaced the cables (flat cable c,k) but the problem persists
      • Dech1
        Senior Engineer
        • Dec 2022
        • 61
        Had this Problem:
        Something you would not of thought of:
        Intermittently the machine would fault out with 61-319. The rap was followed. The magenta and black drums were replaced then the machine started to work. The problem returned then the ROS and the Flat ribbon cables was replaced, also reseated the connection at the MCU pwb.
        Cause:
        Defective IIT PWB
        Replace the IIT PWB PL 13. 8 item 5
        And second time I had the same problem 061-319
        Inizialize IOT NVM and this solved it......
        • Apouthe Donald
          • Mar 2014
          • 82
          thank you for your help, I just replaced the IIT PWB card and I initialized IOT NVM and the cable was replaced but the code remains
