error 093-314 & 093-315 Xerox C60
  • puples
    • Aug 2021
    • 2
    [Error Code] error 093-314 & 093-315 Xerox C60
    Hello,
    i have a problem with a xerox c60.
    I am in France I bought US toners, it did not work on my xerox. I had a "cartridge error" message. So I bought chips to do a "reset".
    Everything worked at the beginning. After a few thousand pages I got the error 093-314. I have been on this website and reset to zero in maintenance mode. After 10-15 copies I got the error 093-315. If I reset to 0 it works each time for a few tens of copies then it gets into error (314 or 315 error code). Note that the impressions are good. Do you have a solution to solve this problem?
    I try with another cartridge and same problem (magenta & yellow)
    Thanks for help.
  • nikolai.aleksie
    • Feb 2016
    • 177
    Re: error 093-314 & 093-315 Xerox C60
    C60 is same as Color 550/560/570
    Check this treads:
    Xerox 560 error 093-314
    xerox 550 - error 093-315
    • adriansto
      • 2386
      Probably dispenser motors dont work.
      • jhalfhide
        • Apr 2015
        • 451
        If it's the dispenser motors, you won't hear them and you won't see toner in the Dev housing openings. If the Dev housing openings are packed full of toner, the dispenser is working but the Dev isn't taking it along. The Dev housings can snap a little gear at the end and a new housing is needed.
        Above all though, I'd be starting with genuine toners with the correct region from your machine.
        Sent from my LYA-L09 using Tapatalk
        • puples
          • Aug 2021
          • 2
          thanks for your help in disassembling, i see both sensor motors are dirty. full of toner powder
          . Maybe it comes from the no?
