Altalink C8155 Scanner unusable after cleaning mirrors
  • crwoo
    • 76
    [Dead] Altalink C8155 Scanner unusable after cleaning mirrors
    Hi, I am working on a Altalink C8155 that the scanner had a gray background before I started.
    I cleaned the mirrors and lens and now the scans have a serious color overlay.
    I used a light to make sure the lens and mirrors are clean, but it does not get any better. They look nice and clear.
    I tried going into service mode and adjust the glass position.
    Please look at my picture and let me know what could be the problem. The scanned sheet was a white sheet with black line squares at an angle.
    I have no idea what to try next,
    Any help is appreciated.
    Thank you
  • crwoo
    • 76
    Turns out I had one if the mirrors reversed after cleaning.
    • MHeon71
      • Oct 2008
      • 487
      Maybe I am missing something. Is there a reason you needed to remove the mirrors? Can you just clean them in place?
      As far as the grey background, did you try turning on the Auto-backround suppression? It should be in the list of settings to make a copy and you can make it a default if you log in as admin. Of course, it will make your copies a little lighter.
