Wockcentre 7830 cyan +90% toner empty, replace chip->same,replace toner->same
  • ATB
    • Jan 2019
    • 79
    Hi, a few months ago I replaced all toners and they are all at least at 90%. Only atypical thing is that the cyan toner arrived with the pull cyan plastic handle (the ones that gets pulled when we open the front cover) broken so I inserted the toner without it.
    Last week I couldn't print as I received a cyan toner empty error (but again all the toners are nearly full). I replaced the chip with same outcome: the machine booted, I heard the typical noise when you put a new toner and after a few minutes: toner empty.
    I replaced the cartridge (original OEM one), with a brand new one (OEM) and got the same message. All others (KMY) are working fine (fingers crossed).
    Machine is in metered mode, no NVM changes, not under contrat (no problem switching to 3rd party mode if that can help).
    Any idea on how to troubleshoot the issue? I have one brand new toner left (and will order some more new chips to recover the opened ones at 90% and the new one).
    I had a look at the service manual but I only found how to replace the toner dispenser assembly. Any idea on how to run root-cause-analysis without having to try random stuff and waste who knows how many chips?
    My only suspect is that the problem might be mechanical: when I insert/remove the cyan there's no friction/click like there is for other toners (see https://youtu.be/Pka9yKko28E ).
    Thanks!
  • xcopytech
    • Aug 2006
    • 1794
    Check cyan dispenser
    • ATB
      • Jan 2019
      • 79
      thanks but could you be specific? There's no mention of dispnser in the service manual, only dispenser motor and dispenser pipe. Check: run diags? Inspect physically?
      • xcopytech
        • Aug 2006
        • 1794
        Spiral rod for cyan is broken in dispenser assy. You have to remove dispenser assy to find.
        • rishadmohamed
          • Jan 2020
          • 25
          You could try and run the dispenser motor for the cyan module. If you hear a ticking sound then the auger is either block or broken
          • ATB
            • Jan 2019
            • 79
            thx!
            dispenser assy=dispenser pipe or the rod in the developer unit? Speaking about a spiral rod I'd guess we're talking developer unit but better safe than sorry
            Searched in service manual and again, no mention of dispenser assy, except one related to the developer unit: in REP 9.14 Developer Housing Assembly (Y, M, C, K)
            That would be ideal as I happen to have 2 spare brand new developer units
            Thanks! I knew how to do that in the Phaser 7500, will search for same tool in WC7830 (but I think it's not the case because when the printer detected a new toner, it kept "rolling" and couldn't hear any unusual sound").
            • xcopytech
              • Aug 2006
              • 1794
              Spiral rod in dispenser assy is broken, remove dispenser assy and check.
              • shinchan
                • May 2011
                • 197
                Originally posted by ATB
                thx!
                find the rod / auger inside the toner dispenser pipe... located exactly under the toner cartridge, above developing unit.
                if the auger is blocked / broken... replace it, at the end of the auger. there is a small spring that acts like a mixer (no 12).. Put it back with new auger.
                usually if auger is blocked / broken, there is a loud noise when machine is running, or the drum auger will also broken.
                Do you use original toner ? or not original toner?
                • ATB
                  • Jan 2019
                  • 79
                  Can you confirm these are the spiral rods you're referring to (Picture taken from a spare developer unit I have) ? If so, I'll do that during this weekend and report back, thx
                  • xcopytech
                    • Aug 2006
                    • 1794
                    Dispenser assy is not same as developer assy. Your problem is in dispenser assy
                    • shinchan
                      • May 2011
                      • 197
                      no.. not that one... that is developing unit...
                      • ATB
                        • Jan 2019
                        • 79
                        And I already mentioned: thanks but could you be specific? There's no mention of dispenser assembly in the service manual, only dispenser motor and dispenser pipe.
                        Would be helpful to explain what/where it is rather than saying what it isn't. Are you referring to the dispenser motor assembly?
                        PL 5.1 Development (1 of 2)
                        Item Part Description
                        1 006R01509 K-Toner (WW)
                        – 006R01513 K-Toner (NA/E)
                        – 006R01517 K-Toner (DMO)
                        2 006R01516 C-Toner (NA/E)
                        – 006R01520 C-Toner (DMO)
                        – 006R01512 C-Toner (WW)
                        3 006R01519 M-Toner (DMO)
                        – 006R01511 M-Toner (WW)
                        – 006R01515 M-Toner (NA/E)
                        4 006R01514 Y-Toner (NA/E)
                        – 006R01518 Y-Toner (DMO)
                        – 006R01510 Y-Toner (WW)
                        5 127K66670 Toner Dispense Motor Assembly
                        (REP 9.13)
                        6 – Dispense Assembly (P/O PL 5.1
                        Item 5)
                        7 127K65930 Toner Dispense Motor (K, C, M, Y)
                        8 113K83244 Toner CRUM Coupler Assembly
                        9 094K92391 Dispense Pipe Assembly (C, M, Y)
                        10 – Guide Assembly (C, M, Y) (P/O PL
                        5.1 Item 9)
                        11 – Auger Gear (Y. M, C) (P/O PL 5.1
                        Item 9)
                        12 – Spring (P/O PL 5.1 Item 9)
                        13 052K96801 Dispenser Pipe (Y) (P/O PL 5.1
                        Item 9)
                        14 052K96811 Dispenser Pipe (M) (P/O PL 5.1
                        Item 9)
                        15 052K96821 Dispenser Pipe (C) (P/O PL 5.1
                        Item 9)
                        16 094K92402 Dispenser Pipe Assembly (K)
                        (Low)
                        – 094K92770 Dispenser Pipe Assembly (K)
                        (High) (4470, 5570)
                        17 – Guide Assembly (P/O PL 5.1 Item
                        16)
                        18 052K96831 Dispenser Pipe (K) (P/O PL 5.1
                        Item 16)
                        19 – Auger Gear (K) (P/O PL 5.1 Item
                        16)
                        20 094K92760 Dispenser Pipe Assembly (Y, M, C,
                        K) (High)
                        – 094K92380 Dispenser Pipe Assembly (Y, M, C,
                        K) (Low)
                        PL 5.2 Development (2 of 2)
                        1 015K77960 Developer Plate
                        2 848K65672 Developer Housing Assembly (K,
                        C, M, Y) (REP 9.14)
                        3 – Housing Assembly (P/O PL 5.2
                        Item 2)
                        4 130K71851 ATC Sensor (K, C, M, Y)
                        5 – Seal (P/O PL 5.2 Item 2)
                        6 675K85030 Developer (K)
                        7 675K85040 Developer (C)
                        8 675K85050 Developer (M)
                        9 675K85060 Developer (Y) (REP 9.15)
                        10 010K91700 Plunger Assembly
                        11 960K49660 ATC PWB
                        12 849E96933 Bracket​
                        • xcopytech
                          • Aug 2006
                          • 1794
                          • ATB
                            • Jan 2019
                            • 79
                            ok, now that is a unique and unambiguous definition, thanks! I'll work on that, try to identify the spiral rod (as it's not shown in the service manual) and report back. Thanks again!
                            • ATB
                              • Jan 2019
                              • 79
                              xcopytech great intuition/experience/sugesstion. all rods except for the cyan one turn freely. The cyan one is not completely stuck but can move only about 5-10 degrees in each direction.
                              I sense no broken/shaky parts inside. Is there a way to get the rod out to inspect? Thx!
