Would Xerox DC700 fuser works in dc242/252?
  • ondemandprint
    • Sep 2016
    • 87
    Hello.
    Can I use fuser module 008R13065 on 220 volt dc242/252?
    I used dc260 fuser 008R13039 without any problems already. Just removed plastic keys.
  • Caffeine
    • 391
    Re: Would Xerox DC700 fuser works in dc242/252?
    Originally posted by ondemandprint
    Hello.
    They're not technically compatible, but not _completely_ incompatible, either, as you saw.
    The 2xx series fusers do NOT have the "half latch fuser" construction which the 700 fusers DO have.
    Using a 2xx fuser in a 700 means that it cannot run in half latch mode, and if the machine tries to engage half latch mode on a 2xx fuser, I don't know if they will cause mechanical issues. Possibility of not applying the correct pressure to all paper types.
    Using a 700 fuser in a 2xx is more problematic because it DOES have the half latch feature, but the 2xx has no way of engaging this, so while it might work, there is a good chance it won't be putting the correct pressure on the paper.
    In both cases, there is a chance the fuser may work ok on plain paper, which is "easy" to fuse, but might not on cardstock.
    YMMV
    • xcopytech
      • Aug 2006
      • 1793
      Just remove plastic keys.
      Half latch settings for dcp700 is nvm settings.
      Fusers are same
      • Caffeine
        • 391
        Fusers are same
        I know it is _implemented_ in NVM, but there something in the fuser that is different on a hardware level, too. I remember clearly that when half-latch was introduced on the 700, the first to get it, that they had a part number for NON-half latch fuser, which was being cleared out of inventory, and a different number (our current part number/008R13065) for the new half latch version.
        Also, check out this bulletin. (The red text being key.)
        I know this is referring to 250 vs 550, but the 550 and 700 fusers are the same. (Only the voltage is different, so in EU, they are the same. Only in the US do we have a different fuser for the 110v 550 and 220v 700.)
        So this warning for 250 vs 550 fuser would equally apply to 250 vs 700 as well.
        Last edited by Caffeine; 08-24-2021, 04:32 PM. Reason: Poor attachment image quality...
        • xcopytech
          • Aug 2006
          • 1793
          Same fusers.
          You can use dcp700 fuser in c550 or in dc250.
          You can use dc250 fuser in c550 or in dcp700.
          All parts in fusera are same.
          C75 fuser is not same.
          Fuser exit sensor in c75 fuser is not same.
          • Caffeine
            • 391
            Same fusers.
            Hmm, ok. Might give it a try if the opportunity presents itself.
            Since they all cost about the same, and with a specific warning that big, and that red, I just never bothered.
            • xcopytech
              • Aug 2006
              • 1793
              Even c75 fuser can be modified for c550, dcp700 and dc250.
              • ondemandprint
                • Sep 2016
                • 87
                Do I need to change any NVM?
                • xcopytech
                  • Aug 2006
                  • 1793
                  No.
                  You can use fuser without any NVM modifications.
                  • WIWA
                    • Mar 2009
                    • 97
                    well fuser are the same the difference are on the lamps 700 runs on 220vac and 242 runs on 120vac I just switch the lamps to prevent fault code from the fuser sensing circuit .
                    Hope this help,
                    Waiwa72 Gonzos build V1.0
                    • Caffeine
                      • 391
                      • xcopytech
                        • Aug 2006
                        • 1793
                        Yes
