I'm a newbie to the forum, so I apologize if this has been covered before and my searches didn't find it.
I've got a 5028 with just over 100,000 copies on it. I'm getting a flashing L4 code which, as I understand it, means I will need to replace the fuser web in less than 1,000 copies.
I purchased a copy of the service manual from an online source and it shows a part number of 600K29650 for the entire web assembly kit (which I prefer to buy because it's so easy to replace). It also shows 600K29640 for the actual web material kit (which appears to be just the roll of consumable material - which means I'd have to spend more time disassembling the original to replace the web material).
In searching for supplies, I'm coming up blank. I have a feeling these part numbers have been replaced by newer part numbers. My manual appears to be dated Jan 95.
First question: Does anyone have the correct part number for the web assembly kit and/or web material kit and maybe a link to a supplier with reasonable prices?
Second question: According to the tag configuration sticker on my copier, tags 8 (replaceable fuser web), 31 (web wrinkle elimination kit) and 37 (low iron/barrel heat roll) are blacked out. The 10.2 web count reset instructions list 5 initial values to use when resetting the NVM web count (w/o tag 8, w/tag 8, w/tag 31, w/tag 37 and finally 5328). Apparently I have all three tags (8, 31 and 37) so what would I use as the initial value?
Final question (I hope): To perform the 10.2 web count reset, I need to enter the diagnostic mode. To enter diagnostic mode, I need to press the "0" key while turning on the copier. When I do that, I see the L4 code followed by an "r9". There's also a "60" in the enlarge/reduce window. What do the "r9" and the "60" mean?
Thanks in advance for any assistance!
Greg
Greg
